I’m trying to source base station observation data from GeoScience Australia Data and Site Logs and I don’t understand the file naming convention of the source data. There is no explanation that explains the naming and its difficult to locate the exact timeframe for my observation data.
I understand the first part is the base station location name i.e. ABMF00GLP0 = Les-Abymes but what is the following in the filename _R_20220180000_01H_30S_MO.crx.gz
Any explanation or help would be greatly appreciated.
20220180000 is the start date and time. 08.01.2022 at 00:00
01H is the log duration. This log lasts 1 hour
30S is the interval. Observations are recorded every 30 seconds
MO probably means that the archive contains meteorological and observation data. And the only thing I couldn’t find was R at the beginning. Maybe AurCORS support can help with this one.
THE DATA IS COMPRESSED IN A ZIP FILE . ALSO NOTE THIS FROM THE SITE
All RINEX data is stored in gzip format; all observation data is also Hatanaka compressed.
SO TO GET RINEX FILES YOU NEED TO CONVERT THE CRX FILES USING CRX2RNX
REGARDS
