Hi. Sorry for my English))
A new version of the TEOBOX software has been released. Version Teobox 1.5.7.
Download here:
http://teodr.one/cdn/soft/TeoBox-1.5.7.1-setup.exe
Theobox features:
Teobox controls the correspondence of the number of images and the number of coordinates before they are processed and compared.
Teobox allows you to filter photos taken with excessive overlap or multiple photos on turns when the copter stops.
During the flight, the copter constantly changes the angle of attack, depending on acceleration, wind strength and flight speed. To compensate for the antenna offset relative to the camera, Teobox takes into account the tilt angle of the copter and makes corrections to the coordinates.
When shooting large areas, duplicate names appear DJI_0001, etc.
To prevent duplicate names, Teobox creates end-to-end numbering for all added photo blocks.
Work with coordinates in meters. Work with the Left and Right coordinate systems.
Writing coordinates into EXIF and CSV file:
Import exact coordinates of image centres from CSV or TXT file without the requirement for file structure obtained after adjustment of satellite measurements.
It is enough to select photos, select a CSV with the coordinates of the centres, specify the desired column order and the coordinates will be recorded in EXIF photos and into the output csv file.
Now you just need to add photos to the processing software, and the coordinates will be read automatically.
Any question? Please ask us.
