plc
(Pierre-Louis Constant)
June 23, 2019, 7:05am
1
Hello,
I have a minor issue with a custom build of ardurover 3.5.1 from source: the main led on the board appears to be disabled.
Compared the parameters from the emlid provided ardurover 3.4 (with which the status LED is functional) with the new build and that dos not appear to be related.
Any idea ?
Thanks in advance,
PLC
Hi @plc ,
Have you tried to run the LED example ? Does it work?
May I ask you to post the screenshot of Emlidtool as well?
plc
June 25, 2019, 1:23pm
4
Hello @tatiana.andreeva ,
Yes the LED is functional. LED example works.
The LED also works through the emlidtool (version 3.4) and when launching the service manually.
Version 3.5.1 cloned from the ardupilot git, compiled with
./waf configure --board=navio2
./waf --targets bin/ardurover
is the one that causes problem. (and not using emlidtool for this version, launched manually, and confirmed as otherwise working with a GCS)
Thanks.
Hi @plc ,
Could you please try to download ardurover pre-built binary and check whether the same LED behavior remains?
plc
June 28, 2019, 6:12am
6
Hi @tatiana.andreeva ,
As a matter of fact the 3.5.1 prebuilt has the same issue, started manually as usual, the core program works but the LED is non functional.
Interesting.
Let me know if there is anywhere I can dig at my end.
Thanks
Hi @plc ,
I’ll try to reproduce it and get back to you with updates.
Hi @plc ,
I’ve tried to run ardurover 3.5.1 on Navio2 and faced the same issue you described. We’ll consider that in the Navio2 next image.
Currently, I’d recommend reaching out with this question to ArduPilot forum or GitHub.
system
(system)
Closed
October 10, 2019, 1:41pm
10
