Loaded Linux then…
(I retyped this best I could)
pi@navio-rpi ~ $ git clone https://github.com/emlid/argupilot.git
Cloning into ‘ardupilot’ . . .
remote: Counting objects: 120360, done.
remote: Compressing obdects: 100% (2/2), done.
remote: Total120360 (delta 2), reused 2 (delta 2), packed-reused 120356
Receiving objects: 100% (120360/120360), done.
Resolving deltas: 100% (85071/85071), done.
pi@navio-rpi ~ $ cd ardupilot/ArduPlane
pi@navio-rpi "/arduardupilot.Arduplane $ make navio
// BUILDROOT=/tmp/ArduPlane.build HAL_BOARD=HAL_BOARD_LINUX HAL_BOARD_SUBTYPE=HALBOARD_SUBTYPE_LINUX_NAVIO TOOLCHAIN=RPI EXTRAFLAGS=DGIT_VERSION="fd17a69c…
%%Paramaters.o
cc1plus: error: unrecognized command line option ‘-std=gnu==11’
…/mk/build_rules.mk:11: recipe for target ‘/tmp/ArduPlane.build/Parameters.o’ failed
make: *** [/tmp/Arduplane.build/Parameters.o] Error 1
pi@navio-rpi ~/ardupilot/ArduPlane $ cd
pi@navio-rpi ~ /ardupilot $ cd ardupilot
pi@navio-rpi ~/ardupilot $ git checkout navio
Branch navio set up to track remote branch navio from origin.
Switched to a new branch ‘navio’
pi@navio-rpi ~/ardupilot $ cd
pi@navio-rpi ~/ardupilot/ArduPlane $ make configure
…/mk/configure.mk2: Warning - A /home/pi/ardupilot.config.mk file has been written
…/mk/configure.mk2: Please edit the file to match your system configuration, if you use a different board or port
pi@navio-rpi ~/ardupilot/ArduPlane $ make navio
//BUILDROOT=/tmp/ArduPlane.build HAL_BOARD…
building /tmp/ArduPlane/.build/Arduplane.cpp
%%ArduPlane.cpp
%%AeduPlane.o
autogenerated :102:14 : warning: ‘void Log_WriteMode(uint8_t)’ declared ‘static’ but never defined [-Wunused-function]
autogenerated :202:14 : warning: ‘bool create_miver_file(const char*)’ declared ‘static’ but never defined [-Wunused-function]
autogenerated :203:14 : warning: ’ bool setup_failsafe_mixing()’ declared ‘static’ but never defined [-Wunused-function]
%% libareries…// it builds lots of libraries at this point//
Building /tmp/ArduPlane.build/Arduplane.elf
%% ArduPlane.elf
Firmware is in Arduplane.elf
pi@navio~rpi "/ardupilot/ArduPlane $
ArduPlane will not launch after much tinkering, any suggestions?
Justin
