Hi All
When I run ArduPlane in a shell with -C /dev/ttyAMA0
it outputs random hex chars and beeps and periodically “pread: Bad file descriptor”
Does anyone know why this happens?
Thanks
/Jacob
Hi All
Thanks
/Jacob
What is the exact command that you use to run it?
sudo ArduPlane -C /dev/ttyAMA0
I have had this issue before, seems that you should use -A with only one telemetry link, or you can do
ArduPlane -C /dev/ttyAMA0 -A /dev/null
ArduPlane -A /dev/ttyAMA0
Dale
