Can reproduce with latest navio2 raspbian image as well as with latest arducopter binary installed which has version 3.6.8
Looking at the tcpdump sudo tcpdump -n udp port 14550 -X the arducopter spams messages (edited for clarity):
GPIO_Sysfs: Unable to get value file descriptor for pin 4.
GPIO_Sysfs: Unable to write pin 16 value.
APM: ArduCopter V3.6.8 (2f409678)
APM: Frame: QUAD
I found that the issue has been reported before in the ardupilot github, but it seems that it has been resolved since ~3.6.0, so I’m a little confused why it’s happening now.
I want interact with the drone using Dronekit via MAVLINK.
When I connected to the drone using e.g. mavproxy.py I noticed that there’s a huge amount of GPIO_Sysfs messages being sent from the arducopter daemon.
It’s not a show-stopper issue, because I can ignore them, but it seemed to have been fixed in the latest versions of Ardupilot, so I wanted to know why I’m still seeing this behavior. Or maybe there’s actually something wrong with my raspberry/navio2 shield’s GPIO pins.
messages. I re-flashed my operating system to make sure and it’s happening with the arduplane image currently on the Navio site. The first message is coming from line 114 of ardupilot/GPIO_Sysfs.cpp at master · ArduPilot/ardupilot · GitHub. Not only does it make MAVProxy unusable but it may indicate an incompatibility or issue with this version of arduplane and the hardware.
I am experiencing exactly the same issue described above. I am using version 3.6.5
GPIO_
SSTABILIZE> ysfs: Unable to write pin 16 value.
APM: ArduCopter V3.6.5 (b5f637fc)
APM: Frame: QUAD
Flight battery 100 percent
