Hi folks!
I’m currently trying to get my Navio 2 to communicate with my 32 bit Basecam BGC board via Mavlink. The gimbal board runs firmware version 2.6 and the Navio 2 runs on the latest non beta image from emlid in combination with AC 3.4.0.
On the Navio 2 I started ArduCopter with - D /dev/ttyUSB0, which should correspond to serial 2 in mission planner (I’m using an USB to serial converter, cp2104).
Then configured the speed of serial 2 to be 115 in combination with protocol 1, to match the requirements of the gimbal controller. But the controller doesn’t recognize anything… that said, with ArduCopter configured the same way on a PixRacer (but without USB to serial converter) it works just fine!
In addition I verified that the cp2104 is working correctly, since I can connect the PixRacer via telemetry to my windows PC using this adapter.
It appears as if other people had problems with this scenario recently, so maybe someone could look into this?
Would be awesome!
Hello, i have my basecam connected to use mavlink and everything works (i can see in basecam mavlink panel all the green connection variables).
Still have some problems on how ardupilot handles the gimbal trough mavlink, i think it is a faulty implementation from the folks at basecam. Their mavlink is still in beta. In particular we have problems with yaw axis always in follow mode and not working as it should.
Well, since the gimbal works with a pixracer it is obviously configured correctly. It just doesn’t work with the Navio2.
Do you use an usb to uart adapter? And what changes did you make in ArduCopter to get things working?
After spending the whole day on this matter, I finally have something like solution:
On my Navio2 the Serial2 (D) doesn’t work at all. No matter what device (osd, gimbal, uart adapter, …) I try to connect via serial 2, it’s not happening. Every other serial works like a charm, regardless of what protocol or baudrate is being used. Strange.
