Hi,If I am using the device name base, only one device ,the application show receiving signal in the rover name,I believe it should say base not rover
Hi Miguel!
ReachView shows the correct values in this case.
On the SNR chart, the receiver you are connected to is always indicated as rover. Even if it is used as base in your setup.
