rob1
(Rob)
January 8, 2017, 11:39am
1
Install Navio Image, Enable picamera using raspi-config, install python-picamera, install apm-navio.
Pi won’t reboot, Green LED flashing 7 times.
I have exaclty the same setup on my Pi2 (without the navio board plugged in) and it works fine.
Any ideas?
Cheers,
Rob
panky
(Benedikt)
January 8, 2017, 2:18pm
2
that usually happens due to misalignment of the camera’s ribbon cable!
rob1
(Rob)
January 8, 2017, 5:03pm
3
Still having issues. Now I get no RCInput on Mission planner, but the python scripts can detect all channels.
panky
(Benedikt)
January 8, 2017, 7:16pm
4
in missionplanner - flight data window - status tab:
can you see the rcin channel’s input for the various channels correctly?
rob1
(Rob)
January 8, 2017, 7:31pm
5
No. When I try to calibrate there is nothing displayed on the “slide bars”. I’ve disconnected the camera and started with a fresj SD card image. It was working fine before i fitted the camera.
panky
(Benedikt)
January 8, 2017, 7:41pm
6
try starting arducopter without any other python scripts!
rob1
(Rob)
January 10, 2017, 9:06pm
7
I’m not running any Python scripts. Tried uninstalling python-picamera. Still no RC input on Mission Planner
There’s a new thread on this topic. I consider the initial issue solved and close this thread.
