you mention the APM/Pixhawk power module in the feature list of the Navio+.
Are the power modules compatible with the original Navio? I could not find the voltage scale they use.
Original Navio does not have a port compatible with a power module (it should NOT be plugged into ADC port as it will damage the board).
But the power module can be used with original Navio with some additional wiring: 5V and GND should be connected to the 5VRPI port and voltage and current sense to the ADC port channels. I’ll check the voltage scale and answer you soon.
Sebastian,
The PM supports batteries up to 4S which will result in voltage scaled up to 3.3V.
