Anyone else having issues with some photos going missing?
I have noticed in the last few days that when I use the photo function and then come back to the office and download the data, that occasionally, photos don’t seem to have uploaded to Emlid 360. Has anyone else noticed this?
I have noticed that it only happens with the photos I upload that I have taken outside of the app.
So, let’s say, for example, I have taken a photo inside a sewer manhole, and I want to save that point in 360. I go and select the code, press the photo icon, find the image in my photo folder, select it, and then record the point.
Now, 90% of the time, there is no issue at all. So, like, if I have done this at 10 different points on the job site, I go to upload the plan and normally all of them will be there, but occasionally 1 or maybe 2, if it’s a bigger job, will not be there. I will then jump on my phone, open that point, see it’s not there, so I go and press edit and add it in, and it’s all good again. So it’s no big deal, not causing major issues. But I don’t remember this happening in the past.
I thought maybe it was an iPhone issue, as last month I finally made the move back to Apple, after being with Android for so many years.
But today I went to do a plan for someone else using his data that he collected with an Android, and he too, had one photo missing from the file.
So it’s not just me, but wondering if others have noticed it as well.
Now that I know it, I will be double checking each photo point after I record them, which sounds bad, but I don’t do too many photos on site, so it should be manageable. But I guess this is also a heads up, if you do upload photos you take outside the app, maybe just double check them before you leave site.
Hi @Ben_Minutoli,
Sorry for the radio silence over here.
So, from the top, do I understand correctly that when you upload photos from your gallery to link them to a specific point, some are not saved or synced to that point? And you have to reupload them? Is that correct?
If so, could you send me a screen recording of the issue at [email protected]? Also, could you share an app report after recreating the issue? You can find it under Profile > Settings > App Settings > Troubleshooting reports, where you can download the app report.
