Hi, i do ESCs calibration and every motors work perfect.
When I try stabilize flight (without props) every motors start in one moment, but if I pull throtle a little down. two motors stops and other stil works.
I am a little scary because in normal flight it can mean a crash.
If it does not matter, I’d like to ask you something else. Its a little mystery.
I’ve been flying for a few days with my Tarot X6.I trying base setup of EDGE and adjust (NO TRIMs) RC Tx (Graupner MX-20), because base set was a lot of fast for me.
I fly only in stabilize mode, some 10 short flights.
Today i fly first takeoff and landing was OK, but after second takeoff drone start shaking and has uncontrollable. It ended in an big crash.
Both flights was only 1 minute long, so no change bateries, no turn off EDGE, only switch Arm.
compass was be calibrated four days ago. No wind.
This is photo of my copter.
Drive system was designed according to Dualsky xcalc application.
Motors XM7010HD-7 v3
ESC PCU60
Prop. 18x5
Completely Dualsky brand.
Actual weight is 5,5kg
Final weight will be 8kg (extra bateries plus camera and gimbal)
That’s why I have no flight video. I do not want to install the camera because I expected some problems.
