I am working on a project which requires me to get the transformation information between two drones. I found that mavros should be able to send UTM coords via TF but it turns out that the provided navio image don’t include tf, and I am not able install tf because of some dependency issue.
I can write my own script using the global_position and the imu data, but it will be nicer if I can directly use the mavros function. Any help will highly appreciated!
thank you so much for your prompt response. I tried to visualizes the full tree of coordinate transforms, but it is empty. I suppose that mavros is not publishing any tf message…
