Thanks for the info.
Gentlemen, good afternoon
I use Navio 2 + rp2 90 degrees position, this support anti vibration work for me ? RTL these files are up to date?
Thank you for making this mount,
For the purpose of our build, we need to adjust the base plate, since the screw holes don’t align with our F330 frame. Would you please share the base plate dxf, fbx, or any other modifiable CAD format?
They are available as STEP models here: GitHub - emlid/hardware: STL and STEP files for Emlid devices and additional accessories
I just finished my first quad. It has the navio2 and I wanted to ask if the anti-vibration mount is really necessary. I understand the anti-vibration should help greatly if I wanted to add a pi camera or something like that but if that’s not the case, does the anti-vibration help the system to work in a better way?
Thanks!
Hi @fernandomvc,
We highly recommend using anti-vibration platform.
Check this article in ArduPilot docs, it explains why it’s required to use the platform.
@tatiana.andreeva thanks for the reply. I will print one of those anti-vibration mounts.
I appreciate your help!
