Antenna Reach M2 Module
Where is it located internally? Which side…specifics pls.
thx
You have to connect external antenna to labeled ANT socket.
Hi @phainein7,
As @timd1971 mentioned, yes the M2 is not built with a internal antenna, it will be require to use this model of GNSS antenna, You can connect it to the M2 via the external connector to receive signal, we have this guide explaining more about the M2 and the antenna placement.
WiFi Antenna…btw, be nice if signal receive strength was in numerical format.
