Hi all. I sure it been asked but just wanted to check. I do all of my corrections in PPK so when I put in the antenna/ Pole height in the field do I need to do then need to put it in again when doing the PPK work to get the correct elevations using emlid studio?
The antenna/pole that was entered in the field is for record keeping. It is used if you want to use RTK in the field. For PPK you are using the raw data so you need to input this into the software that you will be using for PPK.
Thank you. That makes perfect sence now
Hi there,
Feels like I can make some additions here. If you’re working with the Stop’n’Go function of Emlid Studio, you don’t need to enter the antenna height of the rover: the software will take it itself.
Thank you
