The electrical APC of the drawing sure does seem to be a substantial difference between the other specs… which appear to match the NGS ANTINFO calibration data. https://geodesy.noaa.gov/ANTCAL/LoadFile?file=SFESPK6618H_NONE.003 Seems inconsistency here with the drawing… especially the drawing shows L1 higher or above L2??? But the calibration data states L1 is lower???
The drawing only shows 1mm difference of L1 and L2??? The NGS ANTEX shows a difference between L1 (G01)=48.02 and L2 (G02)=35.91 of 12.11mm!!! I would use the ANTEX data.
Depending on the software u r using, i.e. Fieldgenius, it only has a field for L1, so I use the L1 data only, not a average of L1 & L2. But then again not entirely sure.
As for Emlid Flow, maybe you would also use up to L1 only also??? Or average of L1 and L2… I DON’T KNOW since the difference is substantial of 12.11mm, outside the antenna phase center error of +/-2mm.
I put the base over a known point and add the 65mm offset, then I go do my survey work with Emlid flow. If the actual offset was 41.95 then I’ve been almost an inch off my survey work.
Thanks @timd1971 for the advice, not sure why such a precise antenna comes with variable documentation. Can you recommend an antenna with a good known apc from arp? Also on the antenna I have it looks like it has an indicator from where to measure from on the physical antenna itself, I’ll have to get that number myself soon.
I’m almost better off just putting the base antenna over a known point and setting the m2 antenna offset to 0 then I go over a other known point with my rover and I just subtract the difference from the known point from what my rover is telling me.
Example. Know height is 100 but my rover is saying 100.15. Then I’d go back to my m2 base and just add the 0.15.
I see 3 levels of values, ranking from least accurate to most accurate:
Design values
NGS values (relative calibration)
IGS calibration (absolute calibration)
Never trust #1, and only trust #2, if #3 isn’t available.
Regarding the M2, then you should use the L1 value. Also only use/measure to the ARP on the antenna (usually the bottom of the antenna). The nodge you can see on the antenna is for a slant height measurement.
Because, like a lot of things, it’s from China. Not that everything is screwy like that from China, but definitely seems so with antennas I noticed. Their drawings seem incorrect when it comes to the actual APC… i.e. is this the mechanical or electrical distance? They are never clear. Which is why, like the one you have has calibration data from the NGS which they have equipment to verify that data. Which is why you need to use the ANTEX data over everything else.
Careful of ChatGPT… not sure where it pulled that number from.
I would suggest contacting Sparkfun. And also point out their documentation discrepancies.
ArduSimple also may sell that same Chinese model? Not sure. But you can also ask them about this as their similar all-nand antennas you can compare the NGS data and what they tell you to use. I.e. seems you should be using the L1 (G01) UP value for your actual electrical APC.
As far as that NOTCH, not sure what that is about??? Ask Spark about it. You shoukd be measuring to the flush bottom of the antenna for your ARP, then add the APC value for your total Antenna Height.
Thanks, guys, for helping @conner2806 figure it out. I believe it’s also best to reach out to Sparkfun about the offset. I see that they are also quite active in the forum.
I’ve gone through sparkfuns forums on the antenna I have and it seems like they don’t even really know what to use, I feel like this would be basic information. Not sure why it’s so it’s so advanced to know the offset I should use for an antenna. I may have to start a topic with the SparkFun or send an email to NGS.
No reason to write NGS, they will refer you the NGS14.atx file, and to value I mentioned above.
Also, there is no confusion, the values they mentioned are preliminary design values. So again:
This is a design value, so #1. Ignore at all cost when when you #2/#3.
There are multiple APC’s, but for the M2, you need GPS L1 APC, and when you have the NGS/IGS values, those are the ones to use.
Nope, they just haven’t changed their product-description after the NGS calibration was made available. According to antex14.atx file, the calibration was even made on a robot, and has azimuth calibration data, so I’d say it’s 100% trustworthy.
