Hello all
I have read the documentations and read some threads on this forum but not found my answer.
Since Reach and the antenna can be used as RTK GPS I would assume it is very important to get accurate actual position on where the location is being measured by the Reach unit. For example on the Trimble antennas there is for an example a grey line that one should measure the height from.
So where within this grey box of the Tallysman antenna is the position being measured? The
height of the grey box is 14.3mm.
Thanks in advance!
