Hi. I’m using the RX alongside Qfield. My reference system it’s the same, the geoid also. I just can’t get in qfield any difference in values being the antenna height compensation on or off. Being the antenna height 1,945m right?! Can you help me ?
Hi Luis,
Welcome to our forum!
If QField doesn’t support antenna configuration profiles, you need to input the antenna height considering ARP offset. If your pole height is 1.8 m, so 1.945 m is correct - 1.8 m PH + 0.145 m ARP.
