Antenna frequency
Hi, what radio frequency does it work on (MHz)?
Hi @prostosimplyeeeee,
Welcome to our Community Forum!
I’d like to ask which model of Reach receiver you’re currently using (RS/RS2/RS3). Additionally, are you planning to use LoRa or a third-party radio for your setup?
The GNSS antenna supports update rates of 5 Hz and can go up to 10 Hz depending on the settings, providing accurate positioning data at high speeds. You can check our specification datasheet from RS2+ that contains the technical information.
Model A1 vs A3???
