I have an RS2 that I use daily for field surveying work.
I am going to buy an M2 to use it as a GPS Base equipment in those areas where there is no telephone coverage and it does not allow me to receive NTRIP differential corrections.
I want to buy a different antenna than the one in the store since I am not going to mount it on a drone, but on a tribrach-based one. This antenna comes with a standard TNC-K plug.
I do not know where you can buy the cable for the antenna that has one end this plug and the other the plug for the M2.
I just saw the connector for it
https://www.digikey.com/product-detail/en/amphenol-rf/242129/ACX1350-ND/1012027
the antenna I’m looking at is
not sure what the -k is. There are normally TNC or RP-TNC (reverse polarity TNC) I would think this cable should work.
You might want to check this thread also
That is a normal TNC connector on the antenna
Tnc to mcx i have the cable, just waiting for the antenna you describe.
I want to test the large style vs tallysman helical.
But the tallysman helical is truly hard to beat.
Bought the M2 the radio lora and the cable. Thank you
