Alright guys, one last thing and I’m off for the day. I need to know how to cal the navio to see correct amps/current used. Does anyone have a simplified answer for this dummy? Mine stays at 0% though I know it’s pulling something… the sensor has been setup in MP per the instructions and I do get voltage.
Likewise, lol. My voltage is right so I may just tweak the Amps per volt a little at a time until the MP usage comes close to what the charger puts back in.
Calibrating is a must to get proper measurements during flight, the reading might show correct under idle conditions but as soon as you start flying the measurement will be way off. I’ve found calibration to be a pain, but once you have it set up right you are good to go!
