Mission planner shows 150m in altitude, and then -10m, the drone is on the ground without any move, also speed showing 1m/s, I did 3d calibration, compass calibration, what should be done?
Could you list you eq please? Has the drone be on for long?
Rpi3 navio2 dalrc 4in1esc , not powered for long
Ok. I was going to note that as the temperature of the drone rises the elevation reading from the barometer of the drone will drop. This explains a doming effect on the 3D model that sometimes arises on large plots of land.
I don’t think its the heat, any other concern/ tests I should do?
is gps antenna on the top plate can interfere the barometer?
No, the barometer is a standalone pressure-based sensor so the only thing that really affects it is temperature. Signal interference isn’t a concern. I would consider getting the GPS antenna off the plate as that can cause trouble with signal consistency which could explain some position instability.
Hi @roishachar,
Is your barometer covered in foam?
No foam, it’s indoor and navio is inside the 2 plates, does it matter?
That doesn’t answer @andrew.yushkevich question?
You were outside when you did the initial testing correct?
I will try with foam and check for differences, that issue is when rebooting on the floor indoor, so I’m wondering what can take affect on the barometer
I was basing my troubleshooting on the DJI aircraft I have used, but I don’t know enough about your platform to speculate further. Perhaps it does use the GPS in the altitude? Everything else I have seen has been a barometer driven elevation, but if it was using GPS being indoors could be it
Hi @roishachar,
Do you have any updates after tests?
I have done a perfect flight test with great stability, but then suddenly the drone lose control and turn left and crash on a tree, the tree was with a lot of leaves, so no physical impact at all.
how can I investigate the log?
https://drive.google.com/open?id=146uqEPcqWFd9Ew5aIzAK2E56DnBps2LK
Hi @roishachar,
I can see only videos on your Google Drive.
Can you share your log, please?
