All-new Emlid Reach RX: pocket-sized RTK rover for $1599
I am aware of the ports on the receiver.
My question is:
In the event of (the inevitable) battery failure; what recommendations do you make to power the (RS2) receiver alternately?
I know the receiver can be powered via the usb-c port. Is this recommended during use?
What other external power supply specification & portal can be recommended in the event of a battery failure?
We use small powerbanks if it looks like it going to be running close. It only needs to supply the standard 5v/2A power.
Thanks
Hi Adrian,
Reach RX battery provides up to 16 hours of autonomous work. But if your job takes longer, you can power the device with a simple power bank, as Michael mentioned. Standard options like 5V/2A or 5V/3A should work fine.
Talking about Reach RS2/Reach RS2+, you can use the same power bank. There is also an option which is mostly used for permanent bases—powering via RS-232 port. In this case, the voltage should be in the range from 6 V to 40 V. As for power, for operating device it should be not less than 7.5W and not more than 10W.
Thank you Julia
This topic was automatically closed 182 days after the last reply. New replies are no longer allowed.
