after a power OFF/ON, the base changes its config:
ReachView v.0.3.1
Output Path for corrections from ‘serial’ USB 57600baud (my setting) to –> tcpsvr port 9000 ??
and at the bottom of the config file
from GPS_GLONASS_5Hz.cmd (my_setting) to –> GPS_10Hz.cmd ??
and
Base lat, lon, heigth is empty
by the way: Changing the config on the rover is confirmed with a Save config window.
changing the config on the base is not confirmed, only with a web reload I can check the new config.
… will do a flash…
1 hour later:
after the flash it holds the config… so, please ignore this issue…
… strange things happen: the web browser gets updatet suddenly with tcpsvr and GPS…cmd after a while, while the config, if refreshed, still holds my values?
I also had that problem too. Not to mention I am no longer able to get a fix either. I am going to reflash and try again. Are you being able to get a fix? Your setting on Rover is Glonass 5hz and what do you have set to on the base?
@Flavio
I am still in an experimenting state, as long as the devices are unstable. I have GPS and Glonass 5Hz selected on both sides, because I need coordinates every 250ms, at least. Thats why I selected llh as output solution… I do receive some strong signals from Glonass sats. I had often floating and sometimes a fix, but… I am not yet in the field, it is at my house, so the signals are at or around that critical 45 (whatever this is) signal strength mark.
If I put my rover on the roof, I have 10 sats in the green upper area, far more than with 45 signal strength.
I have the following RTCM3 messages selected: 1002 (GPS L1), 1006 (Antenna ref. point), 1008 (antenna type), 1010 (Glonass L1), 1019 (GPS Ephemeris), 1020 (Glonass Ephemeris).
I use Win10 64bit:
I used the GUI guide, NOT the Terminal guide. Installed the Edison drivers and the Phone flash tool. Thats it.
All I have to do is following the steps indicated in the phone flash software. I do not use the flashall.bat-way.
Take care at the end of the flash: Do not unplug to quickly…
With the Edison drivers, you have the possibility to enter Reach via Ethernet over USB.
After flashing, you have to update the ReachView device to the newest version. This can be tricky, because on my side, it works only, if Reach is in a WiFi hotspot with Internet access.
