Is there any consideration to add an optional averaging time to the stakeout function similar to the measuring tool averaging time? This would greatly improve accuracy. Also, a brief stakeout report display once the stakeout is measured to show XYZ deviations from entered point would be great. Thank you for making a great affordable product!
Hi @BlaineS,
Welcome to our forum!
Thank you for sharing your ideas with us. We have such a feature in our roadmap. I’ve added your request as +1 for it and will keep you posted on the updates.
Hi @BlaineS,
Just wanted to say that we’ve added an option to collect the point in stakeout mode and generate a stakeout report in Emlid Flow. This feature is a part of the Survey plan. You can find more details on how to work with it in this guide.
Feel free to test it out and share your feedback with us!
Hi Julia, thank you for getting this feature added. It seems to work great! The only thing I would like to see added is a bearing/distance from the selected point to the staked point. A common staking function is to do offsets and this would greatly help. Thanks again for a great product!
Hello, @BlaineS !
Thank you for your feedback! It is very useful to improve the stakeout in the future.
Could you please share more details about using Bearing and Distance? How exactly will this data help you in your work?
When staking multiple offsets from a point, they need to be along the same bearing line. Knowing the exact distance and bearing from the reference point (point we are trying to stake) and extending outward to the first offset point will help to generate a 2nd offset point. This is a common staking routine for excavation work.
Hi @BlaineS,
Do I understand correctly that you’d like to have equidistant points on the same line? Would you use the values from the stakeout report to calculate these points? Or do you see it working some other way?
We already have the Traverse tool in Emlid Flow, which allows you to create new geometry using existing data. You can specify a new point relative to an existing point by distance, azimuth and height difference. Would it be an option for your workflow?
