Silvain
(Silvain)
February 11, 2019, 9:53am
1
I would like to add a SPI component (MAX31911) in serie with a navio2 board.
For this, I thought cut the link MISO and add the component between.
Do you think that will work?
Could I access my component even if the SPI is used by the Navio library ?
Thanks for your reply
Silvain
Hi @Silvain ,
It seems there is no straightforward way to accomplish it, as all SPI SC pins are already used by Navio2.
Silvain
(Silvain)
February 11, 2019, 4:56pm
4
Ok, but since SPI is a serial bus, Can I intercalate my component at the end of the chain after the Navio2 ?
Hi @Silvain ,
If you’ll be able to use any free pin as a CS, it seems possible to implement.
In that case, I do not recommend to solder your device on the board. It’s better to connect it to the header.
I’m afraid I can’t suggest anything more certain on this question, as I don’t try this kind of integration.
Silvain
(Silvain)
February 14, 2019, 8:25am
6
Hi Tatiana,
Thanks for your reply. I will try on a test board.
system
(system)
Closed
May 26, 2019, 7:30am
8
