I broke the ADC pin input and disconnected a line as seen in the picture.and in this case, my device did not work, although I did not think that there was a critical line in the circuit. If I reconnect the broken line with solder, will the device continue to work properly?, I will not use the ADC pin.
Hi Osman,
Does not it boot at all? Is there any LED indication when you are powering the board?
