Hi Emlid
I have a Navio2 HW, and there is a problem with the adc channels, I tried everything (all the forum related posts) but still getting 0s on all channels.
I would like to know if it is possible to add an ADS1115 ADC and use it on the NAVIO2 HW. Do not know if the NAVIO2 still uses this ADC or another.
Regards
@Luis_Fontana hello! Please run the following command:
cat /sys/kernel/rcio/status/alive
What is the response?
[quote=“Luis_Fontana, post:3, topic:4045”]
[/quote
init_ok and pwm_ok are 0
Usually these problems arise from a loose connection between Navio and Raspberry Pi? Have you screwed down the board?
Thanks George and Mikhail
It was a connection problem.
