Hello! I have only one unit of emlid reach rtk gps. I want to buy the second one so I want to know how much accuracy it has while stake out points and taking coordinates. How much time does it need to take coordinates which has great accuracy?
Thank you for your attention
Is this the original Reach, Reach RS+ or RS2?
Hi Giorgi,
As I understand from your email, you have a Reach Module. With it, you can achieve centimeter-level accuracy in RTK mode.
Please note that Reach Module has been replaced by Reach M+. They can be used together in a base and rover setup as they are fully compatible.
With the single-band receivers in RTK, it could take a few minutes to get a fix solution. This time is only required at the beginning of the survey or in case the fix solution was lost. You can find out more about configuring Reach M+ receivers in this guide.
