I don’t think that it can be done directly, but just an idea, can you do it by installing TeamViewer on a PC or a tablet that can be accessed remotely of course that PC should be connected to the internet, I think also that an Android version of a Teamviewer exist.
Position output menu allows for Bluetooth, Serial, and TCP connections over Wifi. The output is corrected location data. If you want raw GPS logs, you’ll need to access the log files which are not streaming. They can be accessed over WiFi and SSH.
As our users have pointed out already, at the moment, it’s not possible to see the raw data from the rover in real-time. You can, however, organize a position output from the rover via Bluetooth, Serial or TCP. You can find more information on this in the Position Output guide.
You can set up multiple rovers to receive corrections from one base. However, for now, it’s not possible to work with several bases for one rover.
