I want to set up a secure zone on the rpi3. To be specific, I want to port OPTEE.
Is there a place where the source of current Raspian image sits?
Or is there any good other good way you can think of?
Thank you!
Ruide
Thank you!
Ruide
Hi Tatiana,
Thanks for your reply!
Yes, i saw that source before. However, the default entry rpi-3.18.9-rt5 is for kernel image of rpi and rpi2. We are currently using rpi3. Do you know where can i find the kernel source for rpi3? Is rpi-4.14.y-navio the one I am looking for?
Thanks!
Ruide
Hi @rd.cheung,
Yes, you need this branch.
You also can use pi-gen tool for navio to build navio stretch image.
Hi Tatiana,
These are exactly what I need. Thanks a lot!
Ruide
Hi Tatiana,
Turns out rpi-4.14.y-navio is not the exact one I want. The current github branch is version 4.14.34 while the preconfigured image I downloaded is using Linux navio 4.14.95-emlid-v7+ #1 SMP PREEMPT Mon Feb 4 15:59:56 MSK 2019 armv7l GNU/Linux.
I met issues when using 4.14.34 navio kernel with the root file system I extracted from preconfigured image I downloaded. I cross compiled the kernel with bcm2709_navio2_defconfig using linaro toolchain version 6.2.1.
Is it possible for your team to share the source of navio 4.14.95-emlid-v7+ with me?
Or can you point to a place where I can get a working Image and a working rootfs? Currently pi-gen-tool is broken and 4.14.y Image cannot work on preconfigured rootfs.
In the end, I patch the upstream 4.14.95 and make it work.
Thanks!
Ruide
Hi @rd.cheung,
Sorry for the delayed reply!
Do I understand correctly that you’ve resolved the issue? Does it work fine now?
Hi Tatiana,
Not a problem. Thank you for your reply!
Yes, I made it work and for now I haven’t met any issue. Optee is working as expected also. But if it is possible for your team to share the source I mentioned in previous post with me, it would be greatly appreciated! It is totally okay if otherwise.
Thanks!
Ruide
Hi tatiana,
Thanks for the update! I will try it when i can!
Thanks!
Ruide
