A friend of mine was helping me test the NAVIO Raspi combination this weekend and accidently connected the 12 v supply directly to the Navio board vs using an inline BEC. The light on the board came on for a second and then went out
The board will not power on now and I am afraid he may have fried it. Is there anyway for me to run some tests and/or repair the board
You have most likely burnt the LDO and also probably the PCA9685 PWM generator. Is Raspberry Pi ok?
Do you have a multimeter? If so please check voltage on via marked 3.3V.
