Northern Europe shuts down the 3G network in december 2025. We can of course connect to NTRIP via Emlid Flow but isn´t it time to upgrade Emlids modem to 5G for the future?
Another suggestion for the future: In Scandinavia, all CORS with UHF transmission use SATEL protocol. We miss it in RS3.
3G has been shut down for some years in Denmark now.
You can still use a Bluetooth connection to your phone and get internet that way.
By the way, we don’t user radio transmissions from of the 3 major correction services here in Denmark, nor from state operated CORS stations. everything is over internet.
All major constuctionsites and several major cities in Sweden use both internet and radio transmission. As for now, we use BT over our phones.
Regardless of what method to obtain corrections you use, the options (internal modem or radio) should be functional. For future purchases of equiptment, an upgrade of modem in RS3 would be a benefit.
There are no public plans to decommission the 4G network, to my knowlegde? 5G and 4G compliments each other nicely and will continue to do so for years to come.
The RS3 can only receive corrections using the Trimtalk TT450S protocol, so you’re correct that the Satel protocol won’t work with it.
Both the RS2+ and RS3 support 4G connections. In most countries worldwide, 4G is still widely available. Could you tell me why you wouldn’t consider 4G for your setup?
As you know, Sweden, Norway and Finland cover a vast area where several spots with no 4G coverage has existed. These spots are, bit by bit, covered with 5G.
For me personally, I notice a much better performance (in certain areas) downloading corrections via my phone than via RS2+ internal modem. So it is not really a problem.
When it comes to the UHF-radio, I hope in future updates Emlid can add the SATEL protocol. Mainly for the huge infrastructual projects where a short baselenght improves the performance. Pls see example from a railroad site on the westcoast. There are about 11 large constuctionsites with both UHF and NTRIP.
No worries at all. Thanks for explaining your use case. I’ll share your feedback with the team and these suggestions as a feature request for our future devices.
