Has anyone got a solution to connect to a 450 mhz radio
Are you asking about how to connect to a certain radio or about what radios are available?
With what product do you want to use 450 mhz radio?
Reach RS i think is the unit i was look at purchasing.
I have a trimble base with tdl radio , rtcm 3 at 465.81875mhz the rover has 900mhz radio how can i modify rover to receive the 450-470 band width signal please.
Reach RS+ has RS232 communication capability via the optional cable which plugs into the connector in the base of the unit.
You would just need a second radio for receiving. On that is compatible with the one you already have. If it has an RS232 output, then you just need the Reach RS optional cable (probably a CBL103) to connect the two.
I have been told i would have to purchase the reach rs with 450-470mhz radio module, is this an available option.
