Hello everybody,
After reviewing the Docs and Forum, I still have a little brain fog over a proper workflow utilizing two Reach RS2 (one as the base and one as the rover) and the PPK process. I would greatly appreciate a confirmation, correction, or a redirect to an appropriate process. I will be receiving two demo units in a couple of weeks to experiment with and I want to “hit the ground running” to make the most of the 3-day lease.
Background:
I work in a river authority and help manage a sewer pipeline transmission system covering hundreds of square miles. We routinely collect data points for manholes, siphons, meters, etc. This data is used by a GIS system for numerous applications. Currently our survey instruments use an RTK solution - which can be accurate to 4 inches - and require only a 20 second gathering time per survey point.
Objective:
I want to implement the Reach RS2 with a PPK solution to improve accuracy and increase the number of survey instruments available to my workers.
Current Workflow Understanding
- Setup one receiver over an unknown point.
- Set to base mode and begin raw data logging.
- Use average single to receive a placeholder coordinate for the base.
- In corrections output, turn on LoRa radio (will be working in line of sight).
- Setup other receiver as the rover.
- In corrections input, turn on LoRa radio and tune to the base station.
- Setup new survey in the app and log points for 20 - 60 seconds. Repeat for each point.
- Turn off rover unit.
- Stop raw logging in the base unit and then shut it down.
Note: Ideally, my guys would do this in about 15 minutes. Is that feasible? - Return to the office and extract logs.
- Process base and rover logs using data from the nearby CORS station and calculate an absolute base station coordinate.
- Correct the rover units using the corrected base station coordinate as a reference.
- End up with cm accurate, absolute points for the GIS system.
Conclusion
This is my current understanding in a nutshell. Is this workflow correct? Did I miss anything? Are my expectations reasonable? If I misunderstood anything, what is the appropriate solution? Thank you in advance for the help and apologies for the long post!
