Has anyone tried two M2’s for positions? One for the base and one for a rover. What hardware (simple and user friendly) and software would be needed to produce a map depicting bearing and distance, acreage, fences, etc? Thanks! James
Hi @easiwriter,
You can use 2 Reach M2 as a base and a rover.
You need external multi-band antennas for M2. Also, if you want to work in RTK, you may need 2 LoRa radios for sending and receiving corrections.
To draw a map during the survey, you can connect Reach with external software on Android via Bluetooth. This guide describes how to accomplish it.
