I have Reach RS cable without connector. At pin 5 ( yellow) is PPS. Does it work? CanI use it for data synchronization?
Hi
Yes, according to the spec sheet it does, but the schematics hasn`t that pin labeled.
@emlid might have an input on this
RS2 datasheet
Hi Maciej,
You can use the PPS output from Reach receivers through the external connector. The pinout of the connector can be found in our docs. Check it out here.
Checked. Works correctly.
