How is it going? I just wanted to chime in here. Indeed, your observations on the base don’t match the rover’s. Your base’s observations only last around a minute. So once your logs overlap, it will be possible to get the Fixed solution.
If you start the logging on the base but don’t have the logs in the end, please let us know. We will need to check the full system report from the unit to see what was going on, so please share it with us at support@emlid.com.
