hi guys
I have a small problem and I think it’s a small thing but I can’t find the solution and I state that the ESC are already manually calibrated.
when I turn on the system, the engines emit n. 10 beeps at a distance of 2 seconds from each other and then they go to rest with the classic cascade of beeps … from that moment it is possible to arm…
I don’t understand if it is a during timeout which Edge does not give consent to esc (maybe it leaves connection time with UDP systems), or it is a configuration problem.
If so, which command cancels this timeout ?? (as long as it is a timeout)
thanks
