I have read quite a number of posts regarding controlling servos with Navio, but the problem is the different PWM frequencies used, ie ESCs at 490Hz vs servos at 50Hz (or more for digital servos).
As I didn’t want to get a digital servo (and still have to compromise the 490Hz) or get a separate PWM driver board, I ended up using PIGPIO and a spare GPIO pin from the DF13 6-way connector (GPIO 17).
The above command sets the pulse to 1.5ms on GPIO 17 (50Hz).
I am not sure if it is OK to run PIGPIO together with ArduCopter, but will be testing that next. If anyone knows of any possible issues, please let me know.
This is potentially very dangerous!! PPM decoding in APM on Navio+ is based on DMA sampling and pigpio uses same resources. You will have numerous collisions that will result in unpredictable performance. I strongly discourage anyone from using pigpio with APM!
I can see the dependency on pigpio in:
Navio/C++/Examples/PPM-decoder/PPM.cpp
But I cannot see a dependency in the ardupilot codebase?
Can you point me to the pigpio initialisation/code in ardupilot please, I will try to see if I can create an integration point there, so that I can control the servo from arducopter itself.
