your PC’s version is ok. At this time Reach is in a Hotspot-mode at 192.168.42.1 port 9000
you have to enter your local network: name wpa password
then Reach will leave it’s hotspot mode and switch over to your local network, if your entries were correct.
… if you see the “Disconnect” message, you have to switch your laptop/smatphone/PC or whatever you used before to the network, you entered at the first step. Reach is no more in Hotspot-mode at 142.168.42.1.
