Why we need Required observation time?
Hello folks, why we need Required observation time in REACH module?
In what situation are you refering to? The survey mode or base mode maybe?
For survey mode sir. Than what is the difference between survey and base mode sir?
Survey mode
https://docs.emlid.com/reach/common/reachview/survey/
Base mode
https://docs.emlid.com/reach/common/reachview/base-mode/
I think most it is covered in the doc section and for the survey time, its optional to set required time to calculate fix/float/singel position.
Its for ease of use.
k sir thank you. pls keep helping me. Because first time am working on this module
