In order to set up a two-leg SSH tunnel to a middleman server, I’m using system to automatically start a service during the REACH boot process.
The service file is located as required in /lib/systemd/system
It uses an SSH key file located in /home/root
My question is: when REACH is upgraded from version to version, do the two directories above get overwritten, or are they kept
(I’m assuming that during a reflash, everything gets destroyed.)
Thanks in advance. So far, the two-leg SSH tunnel with middleman test is going well.
