Hello,
I have been trying to get arducam OV9281 work with navio2 and rpi4 but after digging i realized its not possible to do so. Is there a work around where I could use the navio flight capabilities with arducopter and also capture camera feed? Do I need to build the os for rpi with support for the camera(as it uses libcamera) and also navio board’s rtk?
Hi Ishraque,
Welcome to the forum! You can read more about video streaming in this guide.
But my problem is emlid doesn’t even recognize the camera model I have. Does this mean I’ll have to change my camera module? The camera connections and everything else is fine beacuse I connected to another rpi with raspbian os and it detects the camera.
Ishraque,
We haven’t tested this particular camera model, so I can hardly suggest specific settings or if it will work. But if you tested with another os and it worked, it does look like Navio doesn’t support it.
