In the field today, I had an issue with the tilt compensation is showing on in the settings, it is reading out values as you tilt it correctly but when you go to collect points, it shows without tilt compensation and can confirm the points are collected without any tilt compensation. The indicator at the top of the screen also shows the tilt is off. Everything has been working fine over the past few months, this happened for the first time today. Rebooted multiple times and it does the same thing.
Hi @MWilco77,
I see that tilt compensation is enabled in the Settings tab, so the IMU is active and reading the tilt values. But since the points are still being collected without compensation, it sounds like the toggle for tilt might be off in the Survey tab.
Could you tap the Plus button in the corner to open the Collector menu and check if the Tilt compensation toggle is enabled there?
Also, do you have a FIX solution when collecting points? Tilt compensation only works when the receiver has FIX.
If everything seems in place and it’s still not working, please share screenshots of your settings. I’m here to help you get it sorted.
The toggle for Tilt Comp was off. It is working as expected now. A coworker that used it before me had toggled it off. Thank you so much for the help and quick response.
Yes, those settings can be easy to overlook. Great to hear it’s all working now!
