I usually use the Trimble Bussines Center for post-processing.
I made a 17 minute observation of a fixed point and trying to calculate, both with the TBC and the rtkpost, the result is unsuccessful.
attached the rinex of the RS2 and the reference antenna
What are you baseline lengths for PP ? Is the point in the open ? I’d recommend at least 30 min for short baselines, minimum 1 hour for longer lengths.
Hi Rafa,
I’ve processed your logs and here is the result:
I had to adjust some parameters for calculation according to our guide on how to analyze the PPK solution. Here is the parameters I’ve used:
Also, I’ve increased the SNR Mask up to 40.
I can PM you all the solution files if needed. I’d also wanted to point out that Bryan’s remarks are really viable for such kind of tasks.
I would appreciate it if you could send me the solution files to have as a guide.
I will be able to work with the rtklib application and the guide. thank you
