I want to share my test results of trying to get a high AR Validation Ratio in continuous mode and not fix & hold! I live in a pretty open area so im not sure this will apply to every project.
Constellations: GPS, GALILEO & SBAS @ 14Hz
Air data rate: 18.23 kb/s
Output power: 20 dBm
1002, 1006, 1097 & 1107 @ 1Hz
1019 @ 0.5Hz
Rover GPS AR mode: continuous
tiedtke
(Thiago - T2R Tech)
August 16, 2017, 3:55am
#2
Hi Brian_Alsum
This test was made in a aerial case (base on ground + drone - aerial) or terrestrial (base and rover on ground)?
Can you tell more about you like the link used (cell, modem/radio)?
Thanks for any information!
Best Regards,
Thiago Tiedtke dos Reis
this was purely the built in LoRa Radio at 915Mhz and 18Kbs
Sorry this was just done with two RS units on the ground.
