Static Data Processing with RS3
I am using Reach RS3 and I tried to process data in static mode. But the software is supporting only Lat, Lon & Ellipsoidal Height. But in My case, I am using local coordinate system called [WGS 84 / Dubai Local TM]( EPSG : 3997 ). Main problem that i am facing the Elevation. Is there any software to process the data?
Hi Ishara,
Welcome to our community!
Would you like to use your point from static processing to set up your base? Then, let’s use the Manual method with these geographic coordinates. You can survey in a project with WGS 84 / Dubai Local TM afterwards.
Can you please elaborate on this? Do you experience some incorrect elevation values?
