Something went wrong
can anyone help me to solve this problem?
When i try to process my static observation using emlid studio, it says, “something went wrong” and there is report below. i couldn’t find the problem
ps . i use RS2
[17:41:45.224] [default] [info] Current session logs directory: “C:/Users/ENMINTECH/AppData/Local/Emlid/Emlid Studio/logs/13.03.2025_17-41-45”
[17:41:45.224] [default] [info] Emlid studio 1.9
[17:41:45.224] [default] [info] OS: “Windows 10 Version 2009”
[17:41:45.224] [default] [info] OS language: “English”
[17:41:45.224] [default] [info] Build CPU architecture: “x86_64”
[17:41:45.224] [default] [info] Current CPU architecture: “x86_64”
[17:41:45.635] [SentryClient] [info] Database uses this path: C:\Users\ENMINTECH\AppData\Local\Emlid\Emlid Studio\sentry
[17:41:45.645] [SentryClient] [info] Debugging: enabled
[17:41:45.645] [SentryClient] [info] Symbolize Stacktraces: enabled
[17:41:45.645] [SentryClient] [info] Enviroment: Windows
[17:41:45.645] [SentryClient] [info] Uses this handler: C:\Program Files\Emlid Studio\crashpad_handler.exe
[17:41:45.645] [SentryClient] [info] Release: v1.9
[17:41:45.645] [SentryClient] [info] Sample rate: 0.1
[17:41:45.963] [SentryClient] [info] Started!
[17:41:46.035] [AntexFile] [warn] More than one atx file was found in bundle directory
[17:41:46.035] [AntexFile] [info] Checking for updates…
[17:41:50.577] [ProcessingManager] [info] ServiceFactory has started
[17:41:50.712] [AppUpdaterWindows] [info] Maintenance Tool path: “C:/Program Files/Emlid Studio/MaintenanceTool.exe”
[17:41:50.712] [AutoUpdateManager] [info] Checking for updates…
[17:41:51.031] [AntexFile] [info] Found a newer version: “igs20_2356.atx”
[17:41:51.031] [AntexFile] [info] Starting the download of a newer version
[17:41:51.594] [AppUpdaterWindows] [info] No updates available!
[17:41:51.611] [AppUpdaterWindows] [info] Updates check finished.
[17:42:11.236] [AntexFile] [info] Path has been changed to: “C:/Users/ENMINTECH/AppData/Local/Emlid/Emlid Studio/resources/igs20_2356.atx”
[17:48:29.400] [ServiceFactoryClient] [info] Successfully created a service “[ServiceId = uniqueId:1, type:Converter]”
[17:49:36.425] [ConversionTracker] [info] Conversion finished: “[Result = type:0, value:(), errorMsg:Failed to move results to output directory]”
[17:49:36.425] [default] [warn] qrc:/qml/Studio/Components/PostProcessing/PostProcessingPanel.qml:185:5: QML Loader: Binding loop detected for property “sourceComponent”
[17:49:36.432] [ConversionTracker] [critical] Failed to move results to output directory
What is your specified output directory?
A post was split to a new topic: Drone data processing error
Hi @arlisasintya,
From the logs, the error is “Failed to move results to output directory”. This usually happens for one of the following reasons:
  • You don’t have permission to write files to your output directory.
  • Not enough available storage on your PC.
  • You’re working from a very deep directory.
I suggest checking if you have the necessary permissions and sufficient storage. Also, please try copying the data to your Desktop and processing it from there.
